stopped working, and i dont know why!!
Old Dec 10, 2009 | 10:14 AM
215stud's Avatar
215stud is an unknown quantity at this point
Default stopped working, and i dont know why!!
hey guys got a 97 blazer and the heater/ ac doesnt work i thought it might be the heater control unit so i bought a new one and put it in still dont work so what do i check and how do i check it and where is everything located where is the blower motor located and how to i take it out?
Old Dec 10, 2009 | 12:19 PM
ABN31B's Avatar
as much as you are not going to like hearing this.... that sounds like a bad/plugged heater core. that means you have some good times in your future....
search it up, there are walk thru's talk thru's and how toos. <-- I'm Dr. Suess!
Old Dec 10, 2009 | 01:11 PM
Well, lets get some things straightened out here first... When you say that your heater/ac does not work, what specifically does not work? Does the blower work? Is that the actual issue or is there more to it?
Old Dec 10, 2009 | 04:12 PM
215stud's Avatar
the blower doesnt work at all, after it gets up to temp going down the road i can feel a little hot air come out of the defrost but it has no force behind it so i thought it might be a blower issue
Old Dec 10, 2009 | 07:15 PM
Is the blower motor inoperative at all speeds? If so, you'll need to check the related fuse and relay.
This diagram might help:
It's been posted before.
Old Dec 10, 2009 | 07:52 PM
215stud's Avatar
where is the relay located and how do i check it?
Old Dec 11, 2009 | 04:01 AM
taba5's Avatar
taba5 is on a distinguished road
for a quick and i mean "quick" fix possibly, you can pop the hood. on the passenger side near the windhshield under the hood you have your blower motor assy. (its a black plastic box snug fit between the fender and the firewall) with the side of your fist give the box a bump and it may kick on..
dOgGiE_VoMiT
Sep 7, 2012 05:24 AM
bobby099
Mar 20, 2012 07:13 PM
jagblazer01
Jan 17, 2012 11:36 AM
timmy08753
Jun 18, 2011 08:57 AM
98BlazerLT4x4
Lifting Tech
Mar 28, 2008 10:55 PM
