Takin out the tranny!!!
so i started to take it apart today, and i ran into a little question. i took off all the nuts and bolts on the bottom and sides, but my question is....are there any bolts/nuts on top of the transsmission?
RE: Takin out the tranny!!!
Well, yeah, there are bolts on the top of the transmission...
This might help you: HOW-TO: 700R4/4L60/4L60E Tranny Removal *Moving to 2nd Gen Tech* |
OK well that guide looks helpful, but i have a 4x4 and is that alot diffrent job than taking out the 2wd?
ok well let me tell you my situation. The other day i was getting into my car put it and reverse doesnt work. blah blah blah. i have it in my garge, im taking it out right now. My question is where is the reverse gear located on the transmission and also do i have to take off the 4x4 part of the transmission? please let me kno ASAP
ORIGINAL: rob1621 OK well that guide looks helpful, but i have a 4x4 and is that alot diffrent job than taking out the 2wd? The transfer case will be taken off as described in the How-To. About your problem, you most likely are experiencing the aftermath of a stripped reaction sun shell. This is used in reverse, 2nd, & 4th. This thread should help: 4L60E Tranny Rebuild Thread |
ok so most likely the sun shell, how about this one? do i need to buy anything else for it or just this?
http://www.transmissionpartsusa.com/...-035823ahd.htm |
That looks like a pretty good part there!! I like how it says the beast of all 4l60e tranni parts!!
I do not know the mileage on the transmission in your truck, but personally, if it has over 75k miles of unknown use/abuse, I would do a full rebuild. You could just replace the sun shell and all of the seals/o-rings that were removed in the process. That is up to you.
ok well what rebuild kit would you guys reccommend? one that will have everything i need.
ok well i was looking at my tranny and i have a question, there is a part between my tranny and the transfer case, its about 4inches wide and goes all around. should i take that off with the tranny or leave it on?
| All times are GMT -5. The time now is 01:30 AM. |
