temp gauge doesn't work
As I recall the sending unit is just above the spark plugs just over 1/2 way back on the driver's side. First make sure the wire is making good connection to the sending unit. If the guage still does not work then take the wire off and connect a jumper wire from the wire terminal to a good ground on the engine. Then turn the key to on. If the guage goes to full the sending unit is bad. If not you have another problem. Do not leave the key on with the jumper wire connected any longer than necessary.
lazer2000
09-16-2012 11:16 PM
zakm0n
01-09-2011 07:31 PM
mboehler
01-16-2009 07:16 AM
Mulisha
03-24-2008 09:14 PM
