temperature and more
Old Jul 11, 2008 | 05:05 PM
jman_08's Avatar
jman_08 is an unknown quantity at this point
Default temperature and more
I have a 2004 blazer and when the A/C is on the temperature runs hotter about 210 or slightly above that when the A/C is off it runs just under 210 Also the blazer has no acceleration and tire spinning power with 3.42 gears and my friends 94 Blazer can roast them around corners mine will spin but not like his does gearing have alot to do with acceleration and tire spinning power Also i believe this is normal but with the A/C on i have slightly less engine power.
Old Jul 11, 2008 | 05:49 PM
rriddle3's Avatar
Default RE: temperature and more
Well, that all sounds pretty normal. You might double check your coolant level, though, or maybe it's time to do a flush and fill.
Old Jul 11, 2008 | 06:43 PM
Yeah, that is quite normal for the summer months. Heat is a byproduct of an A/C system at the other end. So heat directly ahead of the radiator can cause higher engine cooling system temperatures.
Old Jul 11, 2008 | 09:13 PM
jman_08's Avatar
Ok good i was thinking it was pretty normal what about the acceleration and tire spinning power??
Old Jul 12, 2008 | 08:00 AM
rriddle3's Avatar
Anytime you're using available engine power to drive accessories you have less power available for delivery to the rear wheels. The a/c clutch is driven by the serpentine belt and when the clutch is engaged it creates a tension drag on the belt requiring more power usage to keep it working.
Chenzo
Engine & Internal
Mar 29, 2011 01:56 AM
dougs10
Dec 14, 2010 03:24 PM
97Blazer_LSQ
Nov 30, 2009 08:24 AM
ve3nsv
Nov 11, 2009 10:00 PM
ross029
May 6, 2008 10:04 PM
