Thermostat Problem
Old Nov 23, 2007 | 10:28 PM
gocartone's Avatar
gocartone is an unknown quantity at this point
Default Thermostat Problem
Well my thermostat was sticking and threw a check engine light so I put in a new one along with a new seal. Now with the new one in there it doesn't even get up to the same temp as the old one that was sticky and the check engine light came back on. Did I do something wrong installing the new one or could I have been unlucky and got a bad Tstat from the parts store? Thanks for any help.
Old Nov 24, 2007 | 12:04 AM
4lowlife's Avatar
Default RE: Thermostat Problem
Could be a failed coolant temp sensor on engine temp sensor too.
Old Nov 24, 2007 | 12:14 AM
Chevy Lover's Avatar
It's possible to get a bad t/stat if you bought it aftermarket. It's also possible that you didn't get all the air out of the system.
What was the code when your check engine light came on?
Old Nov 24, 2007 | 09:47 AM
Zed's Avatar
Zed
Zed is an unknown quantity at this point
You can try unplugging the battery for a half hour and let the computer reset itself and see if that helps but expect it to run ****ty for about 10/20 minutes afterwards ??
Zed
Old Nov 24, 2007 | 02:54 PM
gocartone's Avatar
I'm not sure what the code is I have it written down at my appartment.. It was definatly a sticky thermostat thought the engine wouldn't heat up above 170deg and you could tell by pulling on the old one that it was sticky. The new one is an aftermarket one. Would not getting all of the air out of the system really cause it to do this? I thought air in the coolant lines made it run hotter? Is there anything else I could have done wrong when installing it? Thanks.
Old Nov 28, 2007 | 05:04 PM
gocartone's Avatar
Alright well I took it out today to find out that the seal had fallen off of the thermostat. Got it back on and made sure it stayed on this time when I put it back in and it's working perfect now
getinmycarihavecandy
Jan 2, 2012 03:16 PM
Blazer Guy
Mar 30, 2011 07:11 PM
joshuaboudreaux
May 25, 2009 09:42 AM
Steeltoe623
May 20, 2009 08:14 AM
2001Blazer4x4
Oct 31, 2004 01:13 PM
