thermostat question
Old Mar 16, 2013 | 11:19 PM
00chevblazer's Avatar
00chevblazer is on a distinguished road
Default thermostat question
Well I've never had troubles with my blazer. Just normal wear here and there. I haven't had much heat this winter if any at all. I know it could be as simple as a flush all the way up to a core replacement.
My truck normally runs at like the first notch on the temp gauge, I think its 160? Now its running under it and hardly warms up even after driving 40 minutes straight to class and back.
My question is does would an electric thermo correct this? I realize its in the 20°'s but I drove my moms trailblazer the other day and she runs steady at 220°… not sure what is goin on with mine. Also how hard is a core replacement? I've watched some videos on youtube and I don't think I want to go down the road of dealing with taking apart my entire dash and possibly run the risk of putting things back together incorrectly.
Old Mar 17, 2013 | 01:40 AM
Twip's Avatar
sounds like your moms trailblazer is running hot at 220°. it should only be 195° along with yours. i know for a fact that yours should look like its running 200°.
to me it sounds like you both need thermostats.
Old Mar 17, 2013 | 07:59 AM
rexmburns's Avatar
Super Moderator
Yeah sounds like you have a bad tstat that's stuck open. Try replacing it with a 195 and see if that fixes your issue!
Old Mar 17, 2013 | 09:17 AM
cleburne red's Avatar
Yeah, I agree with the rest. Sounds like a stuck open thermostat. Had the same problem with my blazer. The needle would barely even get above 100*. New 195* 'stat, and all is better!
Old Mar 17, 2013 | 11:28 AM
Thanks fellas! This might sound kinda silly but where can I pick one of those up at? And is. It a complicated process to install one?
Old Mar 17, 2013 | 11:39 AM
swanman35's Avatar
swanman35 is on a distinguished road
You can get one at probably any auto parts store. Just ask the employees there. It is a very easy installation. I'm sure you can find on google or this forum on how to do it.
Old Mar 17, 2013 | 11:46 AM
It's a real common part. Stocked at any parts store.
Installation is super easy, as well. All I had to remove was a brace for the belt tensioner and my air ducting. Two bolts, and it's off!
USMaverick101
Jan 22, 2007 05:29 PM
walkingtall
Nov 9, 2006 10:44 AM
gmaltese
Aug 23, 2006 09:31 PM
ericmiller5000
Dec 13, 2005 01:26 PM
2001Blazer4x4
Oct 31, 2004 01:13 PM
