third brake light
i just got a vinyl sticker that says BLAZER to cover thethird brake light. after putting it on, i realize that my third brake light is not working. is there a fuse to check or is this kind of an exploratory surgery to find whats wrong
The overlay should have nothing to do with function. There should be a fuse in the main fusebox under the hood, if its not there check the interior fuse box. If the fuse isn't your problem, then you're looking at taking it off and checking the wiring.
i know the sticker didnt do it thats just how i realized it wasnt working. i took off both fuse panels to look for one but i dont really know which fuse to look for. i dont know what it would be called
Its not bulbs... its LED and they can't possibly blow all at once.
Look in the fuse box under the hood. The fuse is labeled STOPLP, its a 20amp fuse and is located (when viewing from the front) it the far drivers side corner of the fusebox.
Underhood fuse block labeled 'CHMSL' for Center High Mount Stop Lamp. You then have two fuses as well, TRCHMSL for trailer center high mount stop lamp, and VECHMSL for vehicle center high mount stop lamp. Obviously, the VECHMSL is the one you want to make sure is working.
