-   -   throttle plate (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/throttle-plate-77268/)
shortstop_55 Feb 15, 2013 04:58 PM
throttle plate
throttle body plate:throttle body plates are designed to replace the factory plates using existing bolt holes, doing this can it hurt my engine 4.3L ?
Twip Feb 15, 2013 05:04 PM
need more info. year and is it TBI or injected? even the injected ones have whats called a throttle blade that controls air flow. if you can, put a picture of what you are talking about to help give us a better idea. you can use the button with a the little mountain on it and paste the internet address in that and it will do the rest for you.
shortstop_55 Feb 23, 2013 08:23 AM
4.3 L (262 cu in) Vortec 4300 L35 V6, SCFI, 190 hp (142 kW)/250 lb·ft (339 N·m) (VIN W)[7] 4wheel drive 4-door and can i descreened the M.A.f. sensor
rriddle3 Feb 23, 2013 10:35 AM
Just leave both parts the way they are. It will be best for you.
