-   -   Thud when stopping (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/thud-when-stopping-73066/)
Tim_1963 Aug 17, 2012 11:42 AM
Thud when stopping
I am getting a loud "thud" or "thunk" after stopping at low speed. It comes form the rear/center of the truck. Is this a U- or CV- joint issue. Anyone fix the problem themselves. 2000 Blazer LS 4WD 163,000 miles
Thx.
chris015 Aug 17, 2012 11:46 AM
id look at the u joints,and maybe the front hubs.
50lb_cat Aug 17, 2012 12:22 PM
+1, check for play in the u joints, hubs and ball joints. U joints are easy, the only problem is if they are stock then they have an internal nylon "clip" that you have to melt out. The new ones have a metal, external clip.
05BlackJimmy Aug 17, 2012 02:34 PM
Check pads/rotors?
step66 Aug 17, 2012 04:44 PM
Rear/center of the unit? U-joints...Any unit over 80-100K should have them replaced any way! Easy job!
bromanjr Aug 18, 2012 10:52 AM
Thx.
You should check your Torsion bar mounts, at the rear of the bars there is a cross-member that goes across and is attached with a mount/hanger on each end. I hear they can be a pain to change but can cause that noise.
chris015 Aug 18, 2012 11:54 AM
Originally Posted by bromanjr (Post 535849)
You should check you Torsion bar mounts, at the rear of the bars there is a cross-member that goes across and is attached with a mount/hanger on each end. I hear they can be a pain to change but can cause that noise.
Its not that. trust me, i drove around for 6 months with both of mine broke. only thing they ever did was clunk while turning.
abig84 Aug 19, 2012 03:20 PM
its its like a thump it might just be the actual axle itself shifting. my 90 fullsize does this usually when you left off the brakes the its kinda springs back to normal position. hard to explain but its kinda normal for a old worn out truck like mine
