-   -   ticking sound and gushing sound (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/ticking-sound-gushing-sound-7936/)
vdog 01-10-2007 02:38 PM
1. My 98 Blazer has a ticking sound that sounds just like the blinker is on (but it's not). Sometimes it goes real fast. Usually quits for awhile and comes back for no apparent reason(s). I had the auto shop at my school replace some "box" where the sound comes from. It was down by the floor on the passenger side. No help. They didn't know what else to do.
2. Sometimes it sounds as if water is gushing around behind the dash.
Any advice on either?
blazinloud 01-10-2007 03:00 PM
RE: ticking sound and gushing sound
could be your ac clutch, and your heater core.......make sure there is no air in the system, and top up the res.
hillbillyinOhio 01-10-2007 03:03 PM
my guess is that you have water in your coolant system, or are low on coolant.
swartlkk 01-10-2007 03:41 PM
ORIGINAL: hillbillyinOhio
LOL... Sure is water in there. Coolant too! haha.
I had to pick. It was too funny.
Anyway, I agree that you probably have AIR in the cooling system that is causing the noise you are experiencing. The gurgling, not the ticking...
vdog 01-10-2007 04:28 PM
I was low on coolant...got that under control i believe...now as far as the ticking goes???? I know someone that says they know of another blazer that does the same thing...so, i'm wondering if it's common?
swartlkk 01-10-2007 04:32 PM
Check the cruise control cable on the engine. Make sure that the vacuum line from the PCV valve in the driver's side valve cover isn't resting on the cruise cable. If it is, then you may be hearing the PCV valve operating...
hillbillyinOhio 01-10-2007 04:45 PM
ha ha, pick on the idiot. just tryin to help. maybe he should check the air in his tires.
DINO55 01-10-2007 04:46 PM
That Fast Intermittent Ticking Sound you are Hearing is usually the first sign of a bad MULTIFUNCTION SWITCH.....
