-   -   Timing chain quest (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/timing-chain-quest-47481/)
blzR Aug 2, 2010 01:09 AM
Timing chain quest
I did a search on IF the timing chain ever needs replacement and it seems no one ever comes right out and says "no" or "yes"(though it seems more like a 'no')
My Blazer is currently at 350,000kms with the original chain still rolling around in there..
so am i safe then?
thanks.
(1995 4.3)
https://blazerforum.com/forum/showth...in+replacement
blzR Aug 2, 2010 11:16 AM
30 views..did i perhaps put a snag in the old "there's no such think as
a dumb question"? I never had such a diffucult time getting a no or yes from peeps..
please, don't make me play the 'bump' game folks, i will you know :).
abig84 Aug 2, 2010 02:41 PM
Over the time the chain starts to develop slack. I've torn apart engines with 200,000 on them and that chain is wobbling around in there I don't know how it didn't fall off. For me it falls in the catagory of it works leave it alone
swartlkk Aug 2, 2010 04:12 PM
First off, how about a little bit of patience. Do not bump a post after waiting ~10 hours, especially on such a none critical question. Also, you should be aware that some people cannot answer at all times of the day... Hence the 24hr requirement stated in the rules of the forum...
The problem really is that it is such a general question that there is no real 'yes' or 'no' option. Timing chains can last 50k or they can last 400k. It comes down to you and what you want to do. If you need some extra peace of mind, tear into it and replace it.
Myself, if it isn't causing any problems and I have no reason to take that part of the truck apart, I would leave it be until it actually caused a problem.
blazerboyz Aug 2, 2010 05:15 PM
If it aint broke dont fix it!!!!!! These engines are carbon copies of there big bro the chevy 350. You will be fine just drive it an enjoy it.
blzR Aug 4, 2010 02:35 AM
Originally Posted by swartlkk (Post 350716)
a little bit of patience,hence the 24hr requirement stated in the rules of the forum....
Good grief..must admit it now, i never even read that until tonight!..THAT should be a STICKY right here in this section,sorry bout that Kyle.
blazerboyzWrote:"If it aint broke dont fix it!"
abig84Wrote"For me it falls in the catagory of it works leave it alone"
Thanks dudes, she(blazer) is now sitting unbothered & resting again, thanks!
