-   -   Towing advice (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/towing-advice-43744/)
ComputerNerdBD 04-24-2010 06:53 PM
Towing advice
Hey guys. I have a 1998 GMC Jimmy 4x4 and I might have to do some towing within the next couple weeks. I have a B&M trans cooler installed and I have RPO code VR4 (TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM) EQLZR HITCH) and UY7 (TRAILER WIRING,7 WIRE,2 LEAD FRONT HARNESS,5 LEAD REAR HARNESS 7 WIRE TRLR HARN) and I have a 4 wire plug connected to it. I have a few questions:
-How much weight (tongue/trailer) can the 4 door 4x4 tow safely? I don't have the weights yet, but I assume at least 3000 pounds trailer weight.
-With the auto trans, I should be using 3. Correct?
-Is towing with these trucks asking for trouble or can it be done safely? Are the transmissions up for the challenge or will I wind up blowing it?
-Is there any other information I should know before towing? Anything else I should check?
Thanks alot.
EDIT: I also have the GU6 rear (AXLE,REAR,3.42 RATIO 3.42R) with the G80 (AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL) if that matters in this case. I also noticed that it has RPO code Z82 (TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH) PROVISION FOR HD TRAILER EQUIP). Does that mean anything?
-Also is it safe to use 4WD when towing a trailer on gravel or wet grass to prevent the Jimmy from getting stuck?
84BlazerS10 04-24-2010 07:56 PM
I don't know about yours but it should say the towing capacity in your owners manual.
CB160 04-24-2010 08:05 PM
I tow a 6x10' enclosed bike trailer with my '98 2-dr 4x4, and have had no worries haulin' two bikes cross country, but it sure beats the snot outta your mileage....I've also towed a 19' Travel trailer with my S-10 P/Up...works fine if you're not in a hurry, or tryin' to cross the Continental Divide ;) A trans cooler wouldn't be a bad idea if you don't have one...
Never had to worry about grass or gravel, just the dirt roads in the desert, no issues with 2wd...
Have fun!!
ComputerNerdBD 04-24-2010 09:07 PM
Have fun!!
So these things (S-10 Truck Series) can actually handle heavier trailers? I thought originally that they aren't really meant for towing but they can do it. I have a trans cooler. B&M 70264 (14400 BTU) tightly fit onto the grille. I don't really care about gas mileage. I only get about 17-18 highway and 9-11 in town anyway. If I am going to tow, it won't be for long anyway. Thanks for the info.
AJBert 04-24-2010 09:18 PM
Sounds like you are pretty much set up for towing. I don't know the exact tongue weight/trailer weight that your specific vehicle is capable of but it should be around 5000lbs. I wouldn't worry about towing the 3000lbs you are planning to tow.
4x4blazerguy 04-24-2010 09:54 PM
A trans cooler is a must. If you have the B&M SuperCooler you have IMHO the best cooler on the market. I run them on both on our Blazer 4x4 & 98 Jeep 5.9 Limited. You shouldn't have any trouble towing 3000#. There is a chart in the Owners Manual. Ours is a 4dr, auto, 4x4 with 3:73 gears & it is rated @ 5000#. With 3:42 gears I believe the rating is a little less, but 3000# is no problem.
I tow with ours sometimes. I just tow in drive. If I notice it starting to shift in & out of OVERDRIVE I will go into 3rd gear.
I towed a 5000# trailer from Kingman AZ to Northern Nevada about 700 miles @ elevations from 3500' to 6700' in the summer without a trans cooler & the tranny got so hot it was blowing fluid out the vent tube. It burned the fluid to BLACK. I had the tranny flushed on a fluid machine had the filter replaced & added a quart of lubeGard. Then about 3000 miles later I had the same thing done & added a B&M SuperCooler. We now have 50,000 more miles on that same tranny with no problems & the fluid is just as clear & clean as it was when it was changed the last time. Yes, 50,000 miles & I have no plans of doing a service until I see the fluid starting to change color or start to smell bad.
The 4L60E transmissions are not weak.
