-   -   Towing sway control (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/towing-sway-control-80061/)
Helter80 06-26-2013 05:25 PM
Towing sway control
Will I need a "sway control unit" if I was using my Blazer to flat tow a car? Or is it just needed it I was towing a trailer? Thanks.
rexazz2 06-26-2013 05:47 PM
I have towed with a homemade tow bar
My mistake was I tied off the steering wheel , found out the first turn that was not right
I would compare using a tow bar to towing a hay wagon
Unless your towing with something larger like a motorhome I would not recommend for long distance or high speed
A car trailer will be a better option plus you gain braking power
Not all trailers use or need sway control , just makes things better
I think some tow bars have sway control built in
