TPS problem?
Hello All. I had a problem with my 2k blazer last Friday. Fuel pump died. To verify fuel issue, mechanic sprayed carb cleaner into the throttle body to see if engine would start and run. It did, we replaced the pump and fixed that problem. Now getting a low TPS Voltage code. Is it damaged and needs to be replaced? I have had the code cleared twice and keeps coming back. Help please!
BTW, pump should be made of gold. Give me an old bolt on the side of the engine, cam driven pump, any day. TIA |
If you use the search here, you will find out how to test the TPS.
I hear you on the mechanical fuel pump wishes. I would love to strip all the electronic guts out of my Blazer , from the engine to tranny. Go old school and go back to the basics, but not even worth the change over of everything. I would get the same mpg, ha, probably better mpg... |
| All times are GMT -5. The time now is 08:09 AM. |
