TPS and VSS - Do they typically fail?
Old Jul 20, 2017 | 10:57 AM
run_girl's Avatar
run_girl is on a distinguished road
Originally Posted by newguy
?????????????????????????????? Yes it would
I haven't had that checked out yet. I'm now dealing with the dreaded P0300 code that tripped last night. I'm going to check for vacuum leaks. I replaced the camshaft sensor (I had a P0302 code earlier yesterday). I do have a crankshaft sensor that will be delivered today as well since my old one is shot.
The overheating issue was caused by a radiator crack. I've since replaced my radiator and I'm no longer having overheating issues.
Old Jul 20, 2017 | 12:23 PM
newguy's Avatar
When the new crankshaft position sensor is installed you will need to have a crankshaft relearn done with a capable scanner. This will set the timing. Then a a camshaft sensor relearn should be done also. Good luck
Old Jul 20, 2017 | 03:54 PM
rxjimmy's Avatar
rxjimmy is on a distinguished road
You are right. I was thinking of a different vehicle I have. Sorry and thanks.
Old Jul 23, 2017 | 11:46 AM
GeorgeLG's Avatar
Given your mileage issues, what are your short and long term fuel trims at idle and 2500 rpm? This can also help diagnose a vacuum leak.
Misfire codes mean that the crank sensors sees a velocity hick up. Could be spark, compression, fuel or vacuum.
Have you done a compression test?
Have you verified strong spark?
What is your CMP retard value?
George
xJakeLIKEShisBLAZERx
Jun 26, 2012 12:01 PM
klote82
Apr 27, 2012 08:22 PM
killerv8sten
Feb 11, 2012 10:14 AM
sirhc76
Feb 8, 2012 09:14 AM
olympia1979
Feb 26, 2010 05:52 PM
