-   -   Trailer hitch on front? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/trailer-hitch-front-86421/)
95blazerlt 07-07-2014 12:31 AM
Looking to install a hitch on the front of the Jimmy so i have a solid recovery point up front. Anyone have one? how did you mount yours?
Dobe Rottie Gang 07-07-2014 09:25 AM
I have one but its mounted on my bumper/bullbar.
blazen_red_4x4 07-07-2014 03:52 PM
15 Attachment(s)
rexmburns had a great solution to this, one I plan to do myself soon
universal 2" trailer hitches bolted inside the frame rails, then stick a shackle receiver, trailer hitch, step ladder, grill, whatever you want on it :D
only works for 4wd frame, but why would you need such a stout recovery point on a 2wd anyway ;)
Originally Posted by rexmburns (Post 515983)
And now for the latest mod just completed like 20 min ago! Well almost I'm still waiting on parts to arrive but the hard part is over.
I got these from Fedex today. I ordered them from Harbor Freight with a coupon for $28 shipped.
https://blazerforum.com/forum/attach...ine=1404766357
I then test fitted them and marked up some holes to be drilled.
Then with everything drilled I pulled out my bag of leftover grade 8 3/8x1" bolts from my landrover project and used them to secure them to the frame.
Here's a shot inside the receiver. You can see that I didn't put a nut on the end of the skid plate bolts but the are semi threaded into the receiver tube as well. I did not want to have to try and fight to get a nut on and off of there everytime I wanted to remove my skid plate.
Yes I added washers before I tightened it!
Once I had everything in place I shot a bit of bedliner on the bolts to make them black so they blend in with everything else.
Heres a couple shots of the final product. Minus the receiver shackles since they aren't in yet. I will post up some pics of them when they get here though.
And just to show the fitment with something actually in the receiver
I am happy with it let me know what you think.
Forist72 07-07-2014 04:04 PM
Very nice Been trying to think of something like that for my blazer might give it a try. Very nice work!!! Could even weld a bull bar/Light bar up to it....HMMMM
Dobe Rottie Gang 07-08-2014 09:35 AM
1 Attachment(s)
https://blazerforum.com/forum/attach...ine=1404830104
swells87 07-08-2014 07:29 PM
1 Attachment(s)
The way Rex did it is probably the easiest with a stock bumper. I built a new bumper for mine and just added one into it. Attachment 31278 It also acts as my licence plate holder
Blazer_4x4 07-08-2014 10:56 PM
3 Attachment(s)
Here's how I did mine, by having a machine shop drill and then tap bolt holes in 1-1/4" to 2" Hitch Adapters. I had them match the spacing and threads of the holes on the factory tow hooks so they'd line up with a minimal amount of swearing. I used the factory tow hook bolts as well.
https://blazerforum.com/forum/attach...ine=1404878182
I had some 1/4 inch plate plasma cut into mounting points "ears"and then welded to the D-ring receivers for mounting my bull bar.
The bull bar can be removed simply by removing the two grade 8 bolts in both receivers and sliding out the D-Ring Receiver Hitch's. A tow ball receiver can be slid into either one of the Hitch Adapter's if desired.
