trailer wiring harness question
Hello all, I'm brand new and don't know my way around very well, so forgive me if this question is slightly misplaced. I'm trying to put a vehicle wiring harness (4-way) onto my 2001 Blazer. When I dug around underneath the back, I uncovered some bundled up wiring that looked like its what I would attach the wiring to (i call this a 'pigtail', is that good vernaculer?) At any rate, the wire colors are yellow, green, brown, blue. Can anyone tell me what these are for? Left/Right blinkers? Brakes? Ground? Reverse? Thanks so much for any help.
RE: trailer wiring harness question
what you found is for the trailer Wires, you can either put a 4 wire flat connector or a 4pin round connector, i put the 4pin round on mine right thru the hole where you would put the pole to lower the tire from underneath.. My spare is inside so thats why i used that spot..I`ll try and get pics for you.
Brown= Parking lights White= Ground Yellow= Right turn Green= Left turn |
Thanks 2002extreme. I've dug around some more and now have 6 wires and a mostly illegible tag to identify them. (I didn't peel back enough tape to notice all the wires, some were shorter) I now have white, light green, dark green, yellow, brown and blue. What little I can make out from the tag says...
wht - grd grn dk - rh turn yel - lh turn brn - rr lps grn lt - bu lps blu lt - ???? ?toflp (complete mystery) Some of those are self explanatory, some aren't. Does this change anything for the 4 wire? or does your color scheme still hold up? Again, many thanks. |
Have a look inside your owners manual for a full explanation of wire application.
There is also a complete list around here somewhere. *Moving to 2nd Gen Tech* |
The color scheme is still the same. The Blue and LT Green won't be used unless your trailer has reverse lights and brakes, and you need a brake controller to use the blue one.
this post answered most of my questions but i have a couple more. so you wont have brake lights if you use the yellow,green, white, and brown? Also i have one of the lighted deals that slides into the receiver and the chevy bowtie lights up. the only wires on it are green and white. when i plug it in it only works when the right turn signal is working and it flashes. whats the deal here?
(Post 176524)
Ken, the blue wire is for electronic brakes, not for the brake light.
Here is a quote from another thread also dug up:
Originally Posted by swartlkk
(Post 44844)
Hmm.. Never heard of an aftermarket owners manual... You could always sign up at MyGMLink.com and download a copy of your factory owners manual...
Trailer Wiring Harness The light-duty trailer wiring is a six-wire harness assembly. The optional heavy-duty trailer wiring is an eight-wire harness assembly. The harnesses are stored under the vehicle, along the passenger-side frame crossmember on two-door vehicles or on the driver's side corner frame rear crossmember on four-door vehicles. The heavy-duty trailer wiring is fused in the engine compartment fuse block. See Fuses and Circuit Breakers on page 5-88. Both harnesses have no connector and should be wired by a qualified electrical technician. The technician can use the following color code chart when connecting the wiring harness to your trailer.
Securely attach the harness to the trailer, then tape or strap it to your vehicle's frame rail. Be sure you leave it loose enough so the wiring doesn't bend or break, but not so loose that it drags on the ground. Store the harness in its original place. Wrap the harness together and tie it neatly so it won't be damaged. If the lighted hitch cap only uses wiring available in the 4 pin connector, then it is limited to the functions available. |
i have a 96 blazer. it has a 4 wire trailer wire connector. everything appears to be hooked up correctly but i cannot get any power to the wires at any time. does anyone know if there is a fuse for these somewhere? the owners manual says that there is one located at the drivers compartment fuse block but i cannot locate it. please help.
I have a 03 Blazer LS 2 door 4x4. What trailer hitch wiring harness do I need??? I was told from Advance Auto that it is #55411. Is this right. Please Help
