trans fluid out exhaust?
I have a 1995 Blazer 4.3 vortek 4x4. I sent the truck to a shop to put a new distributer in it, while it was in the shop they told me it wasn't engaging into 4wd and said it was a vacuum issue. while they had it on the lift messing with the vacuum lines it started spewing smoke through the exhaust, they told me that it was oil and I needed a new motor. after closer inspection i found that it was trans fluid. any ideas?
sounds like you need a new shop. You dont need a new motor just because there is oil being burned. It will probably need either new valve seals or piston rings. I dont think its even possible for trans fluid to get to the exhaust. How did you determine it was trans fluid
BrinkDiamond
03-02-2014 03:50 PM
DaleA
01-13-2009 08:50 PM
v8vairman
04-12-2006 01:43 PM
