transfer case blazer np236 problem
hello,
buy a new (used), or fix it? how to remove it because something is not enough space, somehow? |
The case is broken and it's time for a new, used, or rebuilt transfer case.
6 Attachment(s)
and you know some good shop with all the parts to repair this?
I have a problem with this plug-in, because the wires from the plug fell out, and I do not know how it is to be correctly or is it indifference? |
You should be able to push the wires back into that plug unless the is damage on the ends that hold them in the housing. Also its pretty much impossible to recommend a shop when we don't know where you live.
I exchanged the used complementary but now appeared to me an error abs and does not show speed?
whether this, there are some speed sensors? |
I can't decipher what you are trying to say there?
after changing to the new (used np236) on the dashboard lights ABS, and the speedometer does not work, blazer 1999 4.3l v6
apologizes for mistakes in writing |
