Transfer Case Selector Switch Fix
Old May 11, 2018 | 12:21 PM
rockp2's Avatar
Default A Transfer Case Selector Switch Fix
Recently my 3-button Transfer Case Selector Switch had been mysteriously cutting off (no lights). Removing the switch I found the connector that has the primary applied power feed seemed to be breaking contact. By touching it just right while it was still in place I could make the "2WD" light go on and off. The connector wasn't loose and all the contacts were clean. There was no apparent reason power should be lost.
I removed the switch and took the back off of it. Looking at the two pins on the switch for that connector where they just exited the switch (using a 10x loop) I could see what appeared to be cracks in the solder. I re-flowed the solder (adding about 0.5-1mm of fresh solder per pin) and it fixed the problem. Took me all of about 15 seconds of soldering.
I've attached a wiring diagram of the power feed only if anyone could use it. As you see in the diagram I have the switch disconnected where I made the repair.
Attached Thumbnails Transfer Case Selector Switch Fix-transfer-power-feed.jpg
File Type: pdf
Old May 12, 2018 | 11:10 AM
Congrats on an easy and I'm sure very satisfying fix!
Old May 12, 2018 | 03:39 PM
Zenith's Avatar
Zenith is on a distinguished road
Great post, thanks for the continuing education.
Old May 13, 2018 | 12:57 PM
canadianbacon's Avatar
canadianbacon is on a distinguished road
Thanks for that, mine is sometimes like that too, but on my 4HI button.
Old May 13, 2018 | 01:13 PM
rockp2's Avatar
This is only one fix of a couple different possibilities. Yours could be a problem with the TCCM or vacuum issue.
Old May 14, 2018 | 08:06 PM
El_Beautor's Avatar
Thanks for sharing. This will hopefully help people troubleshoot similar issues.
Flyfishen
Jun 18, 2019 11:22 AM
SWATPARAMEDIC
Jan 1, 2010 03:12 PM
five04ever
Nov 13, 2009 08:03 AM
myblackblazer
Jan 11, 2009 11:15 AM
Jetfixer
Dec 23, 2005 01:54 PM
