-   -   Transmission Hesitates going from P or N to Drive (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/transmission-hesitates-going-p-n-drive-100162/)
NeoBlazin 08-26-2019 01:58 PM
From Park or Neutral, when I place the transmission in Drive it hesitates approx. 2 to 3 seconds before Drive is engaged.
Vehicle: 1995 Chevy Blazer, 4 Door, 4x4 w/ 166K miles
Engine: 4.3L V6 RPO=L35
Transmission: 4L60-E
Work performed to date:
* Performed Transmission F&F Change w/ MaxLife Synthetic and Lucas Transmission Fix
* Cleaned upper intake manifold and replaced fuel regulator
* Installed new fuel filter
* Checked fuel Trims - Good after I replaced fuel regulator
* Replaced EGR valve
* Installed new heated O2 Sensor on header side (before catalytic converter)
* New plugs, Plug Wires, Cap, & Rotor
* Checked air filter - good
* New Serpentine Belt
The transmission F&F change w/Lucas did help the hard shifting between 1st and 2nd.
Any suggestions?
