-   -   Trouble codes 410, 440, 452 (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/trouble-codes-410-440-452-a-61701/)
robrote Aug 2, 2011 07:58 AM
My 99 Blazer, 4X4 has failed inspection due to the SES light being on. I have three codes:
410- Secondary Air Injection System Malfunction
440- Evaporative Emission Control System Malfunction
452- Evaporative Emission Control System Pressure Sensor Low Input
So far, I have replaced the no working AIR pump, replaced the 2 AIR check valves and the gas cap.
My state (Delaware) will fail the car for the SES light being on. That being said, I am on a wild goose chase to determine what is wrong with this thing. The car runs fine, outside horrible gas mileage.
Thanks in advance.
rriddle3 Aug 2, 2011 08:49 AM
Have you worked through the diagnostic steps for these codes?
P0410 Explained
P0440 Explained
P0452 Explained
robrote Oct 14, 2011 09:28 AM
I recall when I did the last fuel pump on this car, the vent hose fitting on the top front of the tank split. I glued, but now thinking that could be causing one of the issues if it has an air leak.
metroid_killer@hotmail.com Jan 15, 2012 01:17 PM
Secondary air injector is mounted under the radiator on the drivers side. When mine went bad it was under warranty and the dealer installed a new one but also remounted the harness and added a "snorkle" with a small vent filter all the way up to the battery this helps keep rain water and road grime out of te air injector preventing future premature failure
