-   -   TRZ Motorsports control arms (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/trz-motorsports-control-arms-81966/)
midnightbluS10 10-07-2013 07:45 AM
2 Attachment(s)
Anyone tried these out? the look like quality stuff and TRZ makes top notch products, so I suspect they are, also.
Upper and Lower Control Arms (Stock Spring) -
https://blazerforum.com/forum/attach...ine=1381149959
Product Description
Includes:
  • 2 Upper Control Arms, 2 Lower Control Arms, Assembled with Balljoints and
  • Control Arm Bushings, and 2 Limiter Bolts.
  • Built-in 7 Degrees of Positive Caster
  • Designed to Replace Stock Control Arms with No Modifications
  • Reduces Weight by up to 15lbs Per Side
  • Uses a Stock Spring and Shock or the QA1 PRO-Coil System
  • Uppers Come with Limiters in Place to Control Front Suspension Travel
  • Designed for Drag Race Applications Where Spindle Caster Can Range from 0 to 10 Degrees
LeWhite 10-07-2013 10:48 AM
The bottoms look like they might lower the ride hight. That and extra caster is something we need. Can they come without thr ball joints cause I want the tall ones? Wonder did the extra caster come from the top or bottom arm?
