Community
Search
Turn Signals Intermittently quite working
Old 12-23-2020, 08:26 PM
GeorgeLG's Avatar
GeorgeLG is on a distinguished road
Originally Posted by mr.vls View Post
The hair dryer is a good idea. I do have a set of factory service manuals and I have been reviewing the wiring diagrams and it seems that I should have power from the IP Turn Fuse to the closed contacts for the M/F HZD switch right to the flasher (HZD to Flasher Light Blu wire). In flasher mode straight from the UH HAZD fuse through the Contacts in M/F Flasher HZD Switch to the flasher (Gray Wire). My plan right now is to remove the flasher and check for power to ground at the flasher. On both the primary and Secondary power (HZD Off Cavity A1 to B2) & (HZD On Cavity B1 to B2) If I have power present than I will double check the relay, and scratch my head for other possibilities.
Its always best to check for voltage with the load still in the circuit because some problems do not manifest themselves with no current as would be the case with the flasher removed from the socket. Best would be to back probe the connector or pierce the wire with a suitable probe on your meter. I can give you links if you like. If you have power on lt blue and gray then its on to the output wires from the MF switch under the column.
George
Old 12-23-2020, 09:27 PM
GeorgeLG's Avatar
Sorry, forgot ... and flasher output on the purple.
George
Old 12-24-2020, 09:21 AM
mr.vls is on a distinguished road
Thanks for the information, But where the flasher sits It will be kind of difficult to back probe the connector and I am not a fan of puncturing the wire. I will probe the wire if I need to but I will start verifying that 12 volts is present.in the cavity. and go from there.
Old 12-24-2020, 10:24 AM
GeorgeLG's Avatar
No problem, When I have to probe a wire I dab it with liquid electrical tape when I'm done. Let us know what you find.
George
Old 12-31-2020, 12:21 AM
wait,
We have Parking lights on these trucks?
shootsright
08-11-2011 08:38 PM
runnin blazer
04-19-2009 07:34 PM
94 S10 Blazer
03-23-2009 04:56 PM
1995blazergirl
08-16-2007 08:03 AM
hillbillyinOhio
11-14-2006 12:12 AM
Quick Reply: Turn Signals Intermittently quite working
