-   -   Underhood Fuse Box (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/underhood-fuse-box-44942/)
mh99506 May 25, 2010 01:08 PM
Underhood Fuse Box
Alright, I have done search after search and I am at my wits end. I cannot find the fuse box under the hood. It is supposed to be on the drivers side, on the side of the wheel well, near the junction box. I found the junction box, has a nice little plastic cover on it and about six wires held down with nuts. But no fuse box to be found. I am very frustrated with it, as I have a reoccuring p0141 and need to start troubleshooting the wiring. Any help, or pictures would be greatly appreciated. Am I crazy to think my particular blazer would just have the fuses on the side of the dash?
DaveHearne May 25, 2010 02:11 PM
It should be just in front of the ABS control unit on the drivers side, about 9" x 6" in size with a single hand bolt holding the top on. It is the S10 Blazer you have I presume?
Check out my profile then look at my album. Check out underhood picture number 2. You will see the fusebox behind my battery. Mine is right hand drive but your fusebox will look the same but be on the opposite side. Your battery should still be on the same side as mine though.
swartlkk May 25, 2010 07:17 PM
The under hood fuse box came into existence around the 98 model year. 96's will not have it.
mh86334 May 26, 2010 10:25 AM
Thank you for the responses, I knew I couldn't be missing something as obvious as a fuse box! I certainly appreciate the help.
BLAZED$H#TBOXCHEV96 Mar 7, 2022 12:45 AM
This please can you tell me where I can locate the other fuses
