Unsolveable Problem. (Cluster Lights, SES, Ser 4WD, Gate Aj)
Old Sep 17, 2008 | 07:59 PM
95Blzr's Avatar
95Blzr is an unknown quantity at this point
Default Unsolveable Problem. (Cluster Lights, SES, Ser 4WD, Gate Aj)
I have noticed something with my new blazer. The SES, Gate ajar light and service 4wd light DO NOT WORK) I though it was the LEDs, but there seems to be no voltage going to them when I have the car on. When I start the car these lights do not light up, everything else works. The LEDs seemed fine tested with a meter. I know the SES light should be on b/c i unplugged the MAF wire and had my code reader hooked up so it would throw a code. I tried reseating all the connections(Pcm, TCM, etc) I looked around for any broken or out of place wires. I have come up empty handed. Maybe its the cluster itself? Also my 4wd works fine goes into 4hi and low. Any help is greatly appreciated. Thanks
Oh 1998 LS 2 Door. ATX. Vin W
Old Sep 20, 2008 | 06:44 PM
95Blzr's Avatar
Default RE: Unsolveable Problem. (Cluster Lights, SES, Ser 4WD, Gate Aj)
Anyone... Could it be the cluster?
Old Sep 28, 2008 | 08:59 AM
BlazinBlue's Avatar
BlazinBlue is an unknown quantity at this point
hey, my suggestion would be to check all the fuses make sure there all in line in there and they are not blown hope this helps
Old Sep 28, 2008 | 02:09 PM
josh05's Avatar
josh05 is an unknown quantity at this point
as a mechanic the only problems ive seen w clusters is all the lights stay lit up all the time so i would guess its something else causing the problem
blazerguy09
Jan 7, 2015 03:26 PM
raider62
Sep 27, 2011 07:56 AM
2003_CHEVY_BLAZER
Jul 26, 2011 09:09 PM
sparkyblazer
Jul 6, 2010 08:49 AM
3kidblazer
Feb 1, 2009 11:22 PM
