-   -   Vacuum hose off (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/vacuum-hose-off-18606/)
bobc997615 03-21-2008 08:25 AM
Vacuum hose off
I have a vacuum hose off by the wiper motor ('01 GMC Jimmy 4WD). It's a 3 way vacuum with a check valve. The plastic line & the long hose to the engine is OK. It's the 4 inch long hose that's loose. (AKA no lower heat duct operation). I can't find where it connects to?
swartlkk 03-21-2008 08:10 PM
RE: Vacuum hose off
If you have a mechanics mirror, you should be able to use it to locate the missing vacuum hose. I'm betting that it has fallen down under the brake booster.
