Valve Tick- 99 Jimmy
Old Nov 30, 2007 | 10:00 PM
charterguy's Avatar
charterguy is an unknown quantity at this point
Default Valve Tick- 99 Jimmy
Background- '99 Jimmy 95k on the clock. The cold weather has just hit and I've noticed two things.
One- oil pressure. Its normally been around 60psi at startup, then dropping to 20psi at warm idle and 45 while running. Recently, now that its getting cold, a few mornings I've noticed it start at 45psi at idle and peg at 80 psi between 2k RPM. Once it warms up, it tends to stay right at 45psi.
Around the same time, I've noticed a LOUD valve tick when cold that gradually goes away as the engine warms, usually going away totally within 3-4 minutes. This is with temps right around freezing outside.
Anyway, oil has 2k miles on Mobil1 5W30.
Is this normal cold weather behavior on these trucks?
Thanks,
Mike
Old Nov 30, 2007 | 10:50 PM
Chevy Lover's Avatar
Default RE: Valve Tick- 99 Jimmy
A ticking noise from the valve train does not sound normal to me. I would install an oil pressure tester and verify the oil pressure first. If the pressure seems ok, then I would remove the valve cover (or covers), on the noisy side (or sides) and check for loose or worn rocker arms, worn rocker *****, or dry rockers.
Next would be plugged or bent push rods, worn lifters and finally a worm camshaft.
Old Dec 1, 2007 | 12:07 AM
Hanr3's Avatar
Make sure you have proper oil level.
Low on oil will cause ticking noise. Being cold the oil gets thicker, harder to flow, and also leads to ticking noise.
When the oil warms up, the ticking noise goes away.
Veryify you indeed do have 5w30 in there. Thicker oil is OK in the summer, you need thinner oil in the winter. Do an oil change.
postal0dude
Jul 13, 2012 11:30 AM
Kat
Dec 29, 2010 08:11 PM
strong blazer
Apr 6, 2008 02:22 PM
Chrisat55
Jan 2, 2007 12:58 AM
Kenigan
Oct 24, 2006 04:37 PM
