Vibration while turning
HELP...I have a 98 Chevy Blazer. It has started to make a noise like two lids clanging together, up front when i make a turn. At the same time it vibrates in the front and then after a going for a few the vibration stops. Can someone give me some suggestions of what it may be...It would be greatly appreciatied....
Kelhaz1966
Kelhaz1966
*Moved to a new thread* - Please post a new thread rather than jumping in on someone else's unrelated thread.
I'm assuming that you have a 4wd truck. If that is the case, have you tried putting it into 4wd? If the noise goes away or changes, check out this thread:
4wd Front Axle Clicking When in 2HI - Goes Away when in 4HI/4LO
Even if it doesn't, it is a direction to go in. You could possibly be experiencing a bad CV joint as well.
mjgraham
Aug 9, 2011 08:01 AM
v7guy
Mar 4, 2008 12:18 PM
S10Blazer
Nov 9, 2007 08:08 PM
