VSS Malfunction...?
I have a 2000 Blazer LS, 2 door, 5 speed, 4x4.
Here are my symptoms: 1. "ABS" light and "E-brake" lights are on 2. speedometer and odometer quit working 3. Right after starting the blazer it has no acceleration power, it spits sputters and jumps. I have to hold the gas to the floor in order for her to come out of it, which it eventually does. This doesn't usually happen though if i let it warm up for 30 minutes though. ...the scanner read that there was a speed sensor malfunction. Do all these symptoms sound like they're being caused by the speed sensor? If they are all caused by the speed sensor, which one do I replace the "wheel speed sensor" or a regular "speed sensor" or is there a difference!? Thanks for the help everyone!! |
Kind of old and I do hope that you found the answer you needed already, but yes, a VSS sensor can cause all of these problems. Recently, another member had very similar symptoms and a simple cleaning of the VSS sensor has seemed to clear them up.
| All times are GMT -5. The time now is 08:11 PM. |
