Weird fuel pump issue
It depends how the PCM is programmed but on yours, the PCM activates the fuel pump relay for 2 to 3 seconds when the ignition is initially turn to the RUN position. If the PCM does not receive data from the crankshaft position sensor during that time, the PCM deactivates the fuel pump relay. The PCM activates the fuel pump relay continuously when the ignition is in the START position, regardless of crankshaft position sensor data. When the ignition is initially turned to the OFF position, the relay stays activated for 2 to 3 seconds, presumably to prime for the next start. Rapidly cycling the ignition between off and run, without giving the PCM a 5 second "time out" between cycles, may cause erratic relay activation.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
gERgMan
Sep 6, 2008 07:27 PM
mytruck2
Dec 13, 2006 04:50 PM
