-   -   Wet Carpet? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/wet-carpet-72837/)
IanD Aug 6, 2012 02:36 PM
Wet Carpet?
Hey everyone, I noticed that my passenger side carpet has been extremely wet after even the mildest of rain. Used the shop-vac, got all of the water out and this morning it's wet again. I've ruled out weather striping mainly because I cannot visibly see any water marks on any of the plastic in the cabin. I noticed after driving that there is quite a bit of water leaking in the wheel well from behind the plastic protective barrier. My cousin wasn't too sure although he had an idea that the _____ cowl (forgot the name) was clogged with leaves.
He also thought that the plastic between the hood and below the wipers could be the culprit, however I thought that this was the inlet for the AC - I could be wrong.
I drive a 00 S10 Blazer by the way.
warthogdriver Aug 6, 2012 06:19 PM
One way to find it is get a helper and your garden hose and have one of you sit inside with the carpet pulled back and move the hose around outside...that may help you zero on location
05BlackJimmy Aug 6, 2012 07:14 PM
Thats what I did, I removed my carpet totaly to dry out the underpadding so it wouldn't go sour or musty and got someone to spray water over the outside working from the bottom to the top and found that my weatherstripping wasn't quite pushed into the channel around the frame. good luck.
mychevyisntheavy Aug 6, 2012 08:21 PM
heater core
warthogdriver Aug 6, 2012 08:40 PM
Originally Posted by mychevyisntheavy (Post 534078)
heater core
maybe, but he didnt mention any coolant smell.
IanD Aug 6, 2012 08:47 PM
Could it be the heater core? I don't know. I REALLY don't feel like pulling back any carpet or taking it out, it's really a last resort (even though it's wet.) I had a theory that there could be a leak in the under body of the blazer but the more and more I think about it the less I feel that's the problem. About that heater core, could that be a possibility? If I'm not working tomorrow I will try and head over to my cousin's to get a second opinion and to have a second set of eyes to help me look around.
IanD Aug 6, 2012 08:48 PM
Yeah, that's right (Warthog.) There is no coolant smell, I dabbed my finger in the drippings and it smelled like water.
247monster Aug 7, 2012 01:03 AM
bad door pins? maybe
user 1016 Aug 7, 2012 03:53 PM
Does the carpet get wet when it's just sitting in the rain? Or, does the water accumulate while driving? Sometimes the seams on the underside by the door can develope a gap. Which is why water would be pushed up while driving.
IanD Aug 7, 2012 05:06 PM
To be honest, I'm not too sure. I just noticed that after a light drizzle the carpet was wet. While driving around the road was more damp than anything, barely any water.
