What does a fuel pulsator dampner do? is it safe to eliminate it with a bypass hose?
Does anyone know what a fuel pulsator dampner does? it sits right above the fuel pump and is plastic. im doing a fuel pump on my 95 S10 4.3 C.P.I. and do not know if i should re-use it. i want to do whats best for the long run. i found a GM tech bulletin that says it can reputre or crack from the ethanol in the gas causing hard starting or no starting and to replace it. included with my new EP381 AC Delco pump kit is a rubber bypass hose that can be used. the instructions say to use what you find there already, either the hose or the pulsator. but do not know the pros and cons. i searched the forums here but found nothing on this pulsator. anyone know what it does? and what happenes if you remove it?
It causes problems
Originally Posted by bigdaddykane93
(Post 547028)
I recently replaced the fuel pump on my 95 blazer and It didn't have a fuel pulse dampener in the vehicle. It was just a piece of fuel line where it should have been. I have had my blazer close to two years and have no problems with the fuel system other than a failed fuel pump. |
Originally Posted by Ramjam2112
(Post 547038)
The Dampener is there to dampen the fuel pulsations coming from the fuel pump to the rest of the system. I have read several reports where it will cause a loss of fuel pressure resulting in stalling. One fellow replaced his with a length of fuel line (rated to 80 psi) and it solved his problems with stalling.
Purrs like a happy cat
(Post 547068)
my new delco pump came with the bypass fuel line in the kit. id rather use the fuel line if im 100 percent sure its ok too. just curious, is your blazer a 4.3 C.P.I ? and does it idle smooth without the pulsator?
Double check the electrical connection inside the tank when installing your fuel pump. I forgot to connect it and I had to drop the tank a second time. read this(last post) 1995 Chevrolet Truck Problem 95 Blazer Won't Start Read Other Comments On This |
wow thats an informative link, thanks. just curious, whats your fuel pressure at now? and what brand fuel did you have and what brand did you buy? thanks again
Fuel pressure
It hovers at about 62 psi after turning ignition on but not cranking.
I got an AC delco I think. I have a 95 blazer 4 door with 4.6 mfi. Want to get an idea of what you are in for? If you haven't dropped a tank before, be careful of the 2 (one up front and one at the rear)rollover vent valves. You will break the nipples off if you aren't careful. Another helpful tip is if you are doing this yourself is to support the fuel tank in the front with blocks to aid in mating the tank to the fill and vent lines when re-instaliing the tank. |
thanks. whats your fuel pressure at now while idling?
thanks again |
Don't know.
(Post 547408)
thanks again My Blazer quit stalling and the fuel pressure holds for several minutes after turning the key on but no crank. I figured the problem solved and moved on to other things. |
(Post 547419)
I never bothered to check. Maybe it's something I should do when I get the time.
