-   -   what are symtoms of a bad egr valve ? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/what-symtoms-bad-egr-valve-1247/)
yzf125 Sep 25, 2005 01:05 PM
I have a rough idle ( not real bad ) with my 02 blazer with 53000 miles on it. I just replaced the o2 sencors a week ago it runs better over all but still have a rough idle. I was told it could be the EGR valve? what would be the symtoms of it going bad ? and what can cause a rough idle . Thanks
m00nwater Sep 25, 2005 04:37 PM
RE: what are symtoms of a bad egr valve ?
When I had EGR problems it was a really rough idle and it stalled when I slowed down as well. I didn't replace the EGR though...I just had it cleaned and had a filter put in it...only cost about $20 or $30 I think...much cheaper than replacing teh whole EGR.
LoLoS10Blazer87 Sep 26, 2005 12:57 AM
yzf, on an '02, a bad EGR would most definitely trigger a "Check Engine" light
m00nwater Sep 26, 2005 12:28 PM
Good point...I forgot to mention that I had my check engine light on when it happens...
swartlkk Sep 26, 2005 01:20 PM
I would agree that a BAD egr would trigger a check engine light, but a dirty one may not. It is possible that some carbon has stuck the valve partially open. The gasket for the egr valve is under $2. If you think that this may be the case, go grab yourself a gasket, take it off, and thoroughly clean the pintle area of the valve.
How is your gas mileage? If it is crappy, then you may have a leak in your fuel injection spider which is located under the upper intake plenum. A leak here would cause a rough idle as well as some other symptoms (that may or may not be noticeable depending on the extent of the leak) while accelerating.
LoLoS10Blazer87 Sep 26, 2005 02:36 PM
Yeah, I'd check any vacuum hoses going to it, make sure none are cracked or leaking. If they're good, take the valve off and clean the area with carb cleaner. Spray some down in the tube that goes to the manifold, make sure there are no large carbon deposits. When you put it back on, throw a new gasket on there and see how it does.
I agree with Kyle, carbon could be keeping the valve from closing all the way so it's running rough, while at the same time not triggering the Check Engine light.
Another sign of a bad EGR valve is a strong exhaust smell coming from the front of the car (provided you don't have an exhaust leak elsewhere).
yzf125 Sep 26, 2005 07:25 PM
Where is the EGR valve located ? I think i see it on the passenger side of the engine but im not sure. Also , When do you need to change the plugs ,cap and rotor ? ( I have 53000 now ) Can these items cause it to idle rough ? My gas milage is around 19 mpg, Thanks for the help guys.
swartlkk Sep 26, 2005 07:43 PM
depending on the use in that 53,000 miles, it is possible that the plugs, wires, cap & rotor need changing. A worn cap/rotor could cause a rough idle, but it would also result in misfires under load (more) and possibly worse symptoms when it is wet outside.
If you are getting 19mpg, then I would lean away from a fuel leak. The EGR valve is located directly on the front of the engine between the throttlebody and the water pump. It is about the size of a soda can, has an electrical connection on the top and is held on by 2 bolts.
yzf125 Sep 27, 2005 09:12 AM
I see you are from New York , What part ? I am from New York also.
swartlkk Sep 27, 2005 09:34 AM
I currently live out in Byron, NY, just west of Rochester. My wife, son, and I will be moving back to our home county (Seneca County in the Finger Lakes) in another month or 2. I just got hired by Goulds Pumps in Auburn, NY.
