What's up with checking my Transmission Fluid??
Ok, so i check it hot and it comes up just below the lowest hole in the dip stick. So I say to myself, "oh i better add just a bit" So I add less than 1/4 quart of fluid. Then I recheck and no matter what it's like ubove the top hole. It's like it jumps. Then I can use my aftermarket pan with a drain plug and let some out. Maybe an 1/8 of a quart. Still above the hole. I let out anther 1/8 or so. Then I'm back below the bottom one:icon_doh:. HELP ME!! I can't get in between those damn marks no matter what I do. What is wrong here? Is a cruel joke? Thanks for any insight.
- Matt 98 Blazer |
I saw the same thing.
Are you checking the fluid with the vehicle running or not? It must be running for an accurate reading.
I add a bit then check it the next day. gives the fluid time to run down the tube.
Originally Posted by kristoph30
(Post 455389)
ok it just doesn't make any sense. :icon_saywhat: I'm adding like a tenth or a twelth of a quart at a time waiting 5 minutes inbetween checking. And it's just right below the low dot. Then all of the sudden, after one add, it jumps to just over the dot. WTF!!! I even waited a day in between. Is my transmission haunted? So frustrating. What could be causing this? This is the 4l60e by the way. Everytime I go over I let out just a bit and it drops below the low dot again. :icon_eek: Should I let it out this time? Cause between a tenth of a quart it's suddenly overfilled?!! Thanks for the help guys!!
- Matt |
do you got a leak ?
or your trans is an atf fluid aholic |
No, there are no leaks. I'm draining out a little and it drops below the dot. Then I add a little and it's like if I put a thimble full in, it skips over the whole range of the dots and goes up past the top one. This is just craziness. I'm about to just leave it at just barely above the top dot and leave it alone. Maybe I should try a new dipstick. Thanks.
- Matt |
Originally Posted by lizardking88mph
(Post 455883)
- Matt Add what you think you need, then check after your next drive. Or, the next morning. :icon_toast: Aaron |
You're checking it running I see, but in Park? I've always checked them in neutral but the 4L60e says in Park & trans hot.
If it's in neutral I suppose the fluid can jump all over the place. |
| All times are GMT -5. The time now is 01:30 AM. |
