-   -   When dropping the gas tank ? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/when-dropping-gas-tank-27031/)
TAZ454 Jan 29, 2009 05:26 PM
Is there enough slack on the hoses and lines ?? How far can the tank go down before you have to dissconnect a line or connection ??
WolfPack Jan 29, 2009 07:44 PM
RE: When dropping the gas tank ?
about 3'?
Not far at all. you'll snap something on the fuel pump, a vent tube, or pull a ground strap. What are you trying to do exactly?
TAZ454 Jan 29, 2009 08:30 PM
ORIGINAL: WolfPack
about 3'?
check out for vacuum leaks bad connections kinked lines, had fuel pump replaced , after 150 miles iam getting a po442 error code
Beckyj636 Jan 31, 2009 01:52 AM
defiantly Lower tank with loving care! That trouble code is most like that roll over valve in the front of the tank. i have the same code :( :))
