Where does this line go.
thanks, will try it
An inspection mirror helps to show where it goes. If the hose is in good shape, you can make sure it doesn't come off again by using a zip-tie as a mini-hose clamp. However, if the vacuum hoses are original, they can be deteriorating and be losing their elasticity. The later could be why the hose came off.
I made a thread on replacing the hoses on my 1999 that has a 4-button controlled transfer case. the Thread is in my signature below.
The vacuum is used in several places on our Blazers. First it is used to supply vacuum to the actuators that direct to where the air goes in our HVAC systems. Second it is used for controlling parts of the 4wd system. On 3-button transfer case models, it it used to engage the front axle and to direct the transfer-case to switch into 4wd mode. On the 4-button transfer case systems (the ones with the additional Auto 4wd) the vacuum for the 4wd system is only used for the front axle engagement with the transfer case controlled electronically.
HostileJava
17
02-02-2024 02:29 PM
zr2dan
14
01-03-2012 06:25 PM
sunnyblueskies
09-12-2011 01:07 PM
