Where does vacuum line enter cruise control box ?
  #21
Old 04-26-2013, 08:56 PM
Captain Hook has a spectacular aura aboutCaptain Hook has a spectacular aura aboutCaptain Hook has a spectacular aura about
Grey wire goes to pin "A" on the module. On the multifunction switch it's on connector "A" pin #12.
  #22
Old 04-26-2013, 09:06 PM
liberatorx2 is on a distinguished road
Hook , sorry guess I been at it too long & done got color blind. Here's where I'm at
Brown with white stripe....working correctly
Brown.......working correctly
Grey..........working correctly (does have voltage with switch on)
Dark blue....working correctly (has voltage when set is pushed)
Black w/white stripe......not sure can't read ohms correctly, gonna grab another meter tomorrow.
Again Man I appreciate all the help.
  #23
Old 04-26-2013, 09:10 PM
No problem. another thing you can try... disconnect the cruise cable from the throttle and tug gently on just the cable. Make sure you're on the cruise cable and not the throttle cable. Just want to see if the cable is attached to the module or broken.
  #24
Old 10-04-2016, 08:48 AM
Slugranch is on a distinguished road
Default cruise control wiring
Originally Posted by Captain Hook View Post
Just double checked the schematic....
At the cruise module:
The brown with white stripe wire should show battery voltage with the brake released, and the ignition in the RUN position. Must show zero volts with brake pedal applied.
Brown wire must show battery voltage with the ignition in the RUN position.
Grey wire must show battery voltage with the cruise switch ON and the ignition in the RUN position.
Dark blue wire must show battery voltage with the cruise switch ON, the ignition in the RUN position, and the SET button pressed.
Black with white stripe wire must show less than 5 ohms resistance to ground at all times.
Does this wiring diagram and colors include a 94 S-10 Blazer?
chevylover5
08-01-2014 02:58 PM
tdbone1
12-25-2012 09:21 AM
deadmanet
01-12-2012 12:07 PM
88jimmah
10-11-2007 08:11 PM
drefda
06-13-2006 01:31 PM
Quick Reply: Where does vacuum line enter cruise control box ?
