-   -   where is security fuse (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/where-security-fuse-3817/)
sbranch Jun 5, 2006 11:15 AM
My security light is staying on, and I want to try to reset it, butcan't find any fuse labeled security? Is it called something else? Thanks
Dory Jun 5, 2006 12:58 PM
RE: where is security fuse
hiya... year of your truck? make, model? not everyone here has a blazer... i need to know what it is first.
sbranch Jun 5, 2006 01:16 PM
Sorry, it is 4wd 2000 Indigo blue Blazer!
Dory Jun 5, 2006 01:43 PM
Ok... heres what I've got for ya then:
pulling the fuse will not reset it. the passlock sensor is most likely bad, which is part of the ignition switch.
try disconnecting the battery and touch the positive and neg. terminals together for 30 seconds, this will clear all codes in the system...but chances are it will come right back on if the passlock is bad
Scooterewski Apr 4, 2008 09:00 PM
to reset the passlock system the chevy dealer told me to turn the key to the ON posistion and leave it there for,"No less than 15 minutes." turn key off and then start the vehicle...should be reset after that
Patty Sep 13, 2008 01:30 PM
[>:]Could this also help me in my situation? I have a 2000 Trailblazer (Uppidy-S10), and the alarm keeps going off after its set. Sometimes 3x's a night. Can anyone tell me if this can also fix my problem? I'm getting really nervous leaving my doors unlocked at night. :(
