-   -   Where is the turn signal/hazard flasher 1998 Blazer (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/where-turn-signal-hazard-flasher-1998-blazer-32244/)
guyd_15 Jul 3, 2009 03:32 PM
First off, thanks to those that helped me resolve my climate control issue with the actuator!!!!
Symptoms of my current problem are, no turn signals or hazard flashers.
I've tried to search out the location of the flasher for the turn signals and hazard flasher. I pulled out the glovebox, radio, dash covers, ashtray/cigarette lighter and the black piece of trim at the bottom of the dash. I still don't see it!!!
All I found was the body control module.
It's a 98 blazer with all options, do the flashers run through the body control module on highline models?
Thanks,
Guy
swartlkk Jul 3, 2009 03:58 PM
The hazard/turn signal flasher is located behind the glove box to the right of the large wiring connector just below the vacuum actuator for the recirc door. You can drop the glove box down out of the way by first removing all of the contents inside. Then lift up on the clip in the upper left corner while rotating the glove box down.
THIS POST shows the steps for dropping the glove box as well as the location of the flasher. The turn signal flasher is held in place by a green strap in the pictures shown in that thread.
guyd_15 Jul 3, 2009 04:21 PM
Wow, that was fast!
I see it in photo #3, I don't know how I could miss it!!!
Thanks, you guys kick a55!!!!
Guy
