-   -   whinning noise coming from tank area (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/whinning-noise-coming-tank-area-78597/)
coleman75 Apr 13, 2013 10:55 PM
i have a 98 blazer v-6 vortec motor and i have a whinning noise coming from fuel tank area not sure what it is or what to check first????
i also have a engine light on with the code p0440 code checked gas cap and fill hose and it all looks good the intake gasket was busted and leaking so i replaced that and after about 30 min of driving the light went off and then after prolly 20 miles or so over 2 days the light came back on..... same code.....what do i need to do i kno enough about car to fix myself as i did the intake job in my backyard PLEASE HELP NEED TO GET INSPECTED
chris015 Apr 14, 2013 08:53 AM
chances are its the fuel pump making the noise,which is normal. you shouldnt beable to hear it really loud,but alot of them do make a noise. Doesnt mean its bad,but some are loud.
Twip Apr 14, 2013 04:55 PM
i would get a new gas cap...its probably your problem. or you arent making it click enough when you are putting it on. a buddy of mine had to click his 3 times or it would throw on a CEL. if you clicked it 2 or 4, it would throw the light on.
as far as your tank making noise, you should start saving for a fuel pump. it might be on its way out. i have 2 98's and one has a new fuel pump in it. you cant even hear it. my other one is super loud and i am dreading having to do it. but o-well.
cleburne red Apr 14, 2013 05:34 PM
My first Delco pump I put in was quiet. Couldn't hear it at all. I had some fuel system problems, thought it was the pump (but I don't think it was... kept the first pump as a spare), so I bought another Delco and put in. That second pump is much louder than the first. You can hear it in or outside the truck.
If it's always made a noise, I wouldn't worry too much about it. But if it has always been quiet, and suddenly starts making noise, probably best to start saving up for a new pump.
Apr 14, 2013 07:38 PM
You don't need much of a hole in the fuel filler neck to get a code.
rexmburns Apr 14, 2013 09:57 PM
My fuel pump is loud as crap! But it seams to be working just fine so I'm not going to fix what ain't broken:)
