will start but wont stay that way please help
could the ignition control module be the reason my blazer wont stay started. died the other day and wouldnt start back up. once it did it idled fine but would back fire when reved. now it will start but then hesitates really bad and eventually dies. fuel pump does click on and there seems to be plenty of pressure. any ideas would be of great help. thanks
Justin |
RE: will start but wont stay that way please help
so from trying to start blazer the battery ran too low to turn over. i charged it and the next day when i put it back in its like my blazer never had a problem. can someone please please please tell me what might have been the problem and if it truly isnt a problem any more. im afraid to drive it especially if it stalls again.
Have the battery and alternator tested, check the plug wire connections, test the fuel pressure, install a new fuel filter, see how it does.
car died again today twice.and still will start up.fuel pressure must be fine for it to be doing that. but i will check what you mentioned. thanks and if anyone else wants to throw something in please do!!
fuel filter is fine. fuel pump and fuel pressure are good. problem is that for some unknown reason it will die without warning. it will turn over right away after dieing but wont restart.after it dies it will (after a little bit of time) restart and drive again but also dies again. it is now once again towed into the driveway where it sits and acts like there is nothing wrong with it besides small little back fires from reving it up. i dont have a code scanner and the auto parts store does not rent them out to anyone. they dont even have the equipment to test my ignition control module although 30 others they can test but not mine. i need some serious help PLEASE!!!
You cannot assume that the fuel pressure is good. Have you put a gauge on it? On a few vehicles, I actually had to drive around with my gauge attached to the fuel rail to monitor the pressure while driving so I could see what happened to the pressure when the problem occurred. With my new scan tool, that is a thing of the past (real time monitoring FTW)!
But yeah, unless you have verified the pressure, with a gauge, you really do not know if it is proper or not. A poor connection to the pump could cause intermittent stalling. Then there is the ignition switch that could be the culprit... Do you ever notice the security light on your dash illuminating before or at the time of the stall? |
i dont have a fuel pressure gauge. i justassumed the pressure was fine being that it starts right up and will stay that way and even for what driving you could get out of it before it dies. and when it dies you could wiggle wiresand bump the gas tank all you want it wont restart until the car cools down a bit. people say the blazer wont even start if it doesnt have enough pressure so i figured it did. looking to buy a scan tool anyways so i might have to look into that live monitoring.
i have not been in it when it dies. G/F drives it while im at work with my other car. she says she never noticed the security light come on or do anything wierd at all each time it has died. and each time it has been mid day when its the warmest out and the blazer has to cool down somewhat before it starts up again but if you drive it again after that shortly after it dies again. something diffrent i have noticed ever since it died the first time is a little backfire when it is reved up. not sure why its doing that but it still idles fine. would a scan tool tell me if its the ignition switch?? on vacation this coming week and need the blazer back up and running so g/f can drive it to work. hope you can help. thanks |
Chech the connection to the battery. This sort of thing happened to my blazer and I just installed new cables and never had a problem sense. If you don't want to buy he new cables right away can try cleaning the contacts and using a copper or silver washer (which they do have) to create a better contact. hope this helps
your blazer would stall and it was because of battery cables?? when i took my battery out to charge it back up there was a lot of corrosion on positive cable. i cleaned it up pretty good or so i think and it still stalled.
I have very similar issues with my Blazer... Unfortunately, there is no easy way to diagnose every possibility with certainty. I have just changed the ICM and mine still stalled out after 15 miles of driving. My next planned change will be the ignition switch located in the steering column. My local auto store wants$120.00 for an AC Delco switch.. RockAuto wants $98.00+ $10.00 shipping for the same....I need to remove the switch from the columnto know if it's a 4 pin or 3 pin connector before I can order the part.
| All times are GMT -5. The time now is 07:35 PM. |
