-   -   Worth replacing water pump as "preventative maintenance"? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/worth-replacing-water-pump-preventative-maintenance-36807/)
chipjumper 11-09-2009 01:59 PM
2000 S-10 4.3 (w) 4x4
I'm replacing the idler and tensior pulley's right now. Is it worth replacing the water pump while I'm getting my hands dirty? The water pump is original and has 182,000 miles on it.
neo71665 11-09-2009 02:00 PM
A bit overboard in my book but if it helps you sleep better at night be my guest.
richjoe 11-09-2009 02:57 PM
good luck with that nut holding fan assembly. i really struggled getting it off. one tip make sure you have a wench that fits it. and spray the heck out of it (PB Blaster)
terry s 11-09-2009 07:12 PM
You never know how long a water pump will last. But at 182,000 I doubt if it will last much longer.:icon_wink:
blazin_j 11-10-2009 10:53 AM
I would. Mine went at 275k km's when it was -30 Celsius and I had my son with me. Just barely made it home, was smoking the whole way home. Definitely a crappy situation to be in. And I don't have a garage either so replacing it was extra fun.
Randy Jones 09-11-2019 10:26 PM
https://cimg0.ibsrv.net/gimg/blazerf...44b72c0d41.jpg
Old cheap set of cresent wrenches bought Western Auto years ago.. MADE IN CHINA junk.. any way never stayed set , floppy jaws . PIA.. Need to replace water pump on 99 Blazer and new Radiator Do a 1 time and Done with it. well fited the Wrench to fan Hub.. took the set screw out to make it long and fit fan nut. marked it. took to a local machine shop for tack weld . and forget 36mm ?? but he charged me $5.00 for the very simple tacks with welder. Used it. then painted it to find easiy later...
https://cimg2.ibsrv.net/gimg/blazerf...a74afeaee1.jpg
Home made fan nut wrench
fits a Blazer of course and a Dodge 1500 4x4 truck and i'm sure other Brands 36mm if I recall correctly any way. for Laying around a un used Piece of China Junk from the 90's.. it works .. just short on handle length, so a open end wrench in end for a cheater to make length longer..
christine_208 09-11-2019 11:20 PM
I figure it is a bit of a crap shoot: Replacing the original before it fails or causing more issues by digging into the engine. In the end, I thought about doing it but decided to leave it as is. I'm at 140,000 miles.
christine_208 09-11-2019 11:23 PM
If you do replace it, find a high quality replacement. I found an supreme duty one by Cardone, pn 5511311H.
odat 09-12-2019 12:32 AM
Originally Posted by Randy Jones (Post 713379)
A air impact chisel with the punch attachment end inserted breaks the nut loose in seconds along with re tighting them
Tom A 09-12-2019 09:22 AM
Even better, if you're going to do more than one or two fan clutches, It makes the job a piece of cake.
https://cimg5.ibsrv.net/gimg/blazerf...838e033020.jpg
