Fabric8 |
07-15-2018 03:03 PM |
Yet another 2002 ZR2 Died while driving
Hey Y'all I joined the forum in hopes of a knowledgeable Blazer Pro could help. I have a 2002 ZR2, I had a few things happen in the last few months that I believe are related. On two separate occasions, when I get in to start the vehicle, it would crank, but would not start. I always wait for the fuel pump to prime before I start any vehicle. I tried twice more, same, crank no start. So i waited for a few mins, tried again, Voila! Started, and life was good. Earlier this week I was driving on the freeway going 65, I gave a little bit more gas to get up to speed limit of 70 and it jerked, like it was gonna downshift but couldn't. I found that odd because I was not going up hill, and did not give enough gas to warrant a downshift. My first thought was low tranny fluid. I stopped at autozone, I checked the level, it was on the upper end of the dipstick. Now yesterday, I left for work, I got 3 miles down the road, it hesitated again, but this time it died. I coasted to a stop, I gave it some time and tried to start. Crank no start. So I called my buddy, he towed it back to my house. First thing we checked was spark, which we had, we then took the distributor cap off, points were a little glazed. Took the rotor off, we seen on the bottom of the rotor was a little melted plastic. It looked like the spark, instead of firing at the point, fired through the rotor and went down the Dist. Drive Shaft to ground. Simple, we thought we had it. Also the battery never died, I was able to test crank over 10 times, it was a strong crank, wasn't weak. There were no codes either. When we got it back to the house i put it on the charger. So, I got a new ACDelco rotor and cap, installed it, same crank no start. So, I kept the battery on the charger all night. I went this morning to buy a fuel pressure gauge to check fuel rail pressure, and starter fluid. The previous owner upgraded to MPFI. I hooked the gauge up to the fuel rail and when the pump is priming I had 60 psi, after it primed, pressure showed 45. So I figured I would try to start it while the fuel is still priming, It started and ran just fine. (Rules out timing) After letting it run, I turned it off, and just to test out my theory I figured I would attempt start after the fuel pump primed and pressure is at 45. It starts, so now I cant replicate the problem. Im worried that the problem is still there, and it will wait to shut down again in the middle of the night, while im an hour away from home in a thunderstorm. Anybody have any ideas???? When i bought it last Nov the guy gave me a list of things he had done recently.
