How to: 2" Shackle / Torsion Lift - DISCUSSION THREAD
What you will need:
-Lift shackles -A jack that can jack on the rear differential -2 jack stands -Tire chocks -Wrenches -small sledge hammer (2.5 lb. works) -1/4" punch -Spray lubricant -Tape measure -Very level ground Things you might need: -a large (8" minimum i believe) C clamp -Breaker bar -lots of time -patience You will start by chocking the front tire(s) http://i578.photobucket.com/albums/s...dom/Chocks.jpg Then jack up the rear of your truck. (jack under the differential works) You will need to get the tires a good way off the ground as the tires and axle will need to be lowered to allow for the longer shackles. (About 3-5 inches of space between them and the ground should work.) Then place your jack stands under your truck to hold it in place and allow the axle to drop. http://i578.photobucket.com/albums/s...JackStands.jpg Next, you will lower the jack under your rear differential and relieve the compression of the springs holding a bind on the 4 bolts that go through your shackles and leaf springs. Disconnect your rear shock absorbers from the axle by removing the bolt that holds them in place. (1 per shock absorber) This will allow for the axle to drop sufficiently to install the longer shackles. Otherwise, the shock absorbers limit it's travel. Loosen the nut on the 4 bolts running though your leaf springs and shackles. (2 on each side) You will need to back them with another wrench or ratchet. http://i578.photobucket.com/albums/s...m/Wrenches.jpg Leave the nut on the bolt so that you can pound the bolt out without damaging the threads. Next is the moment of truth, remove your backing wrench and turn the bolt around inside the bushing, spraying your lubricant as you turn. If it eventually moves freely or easier, then you are in the clear. If it is stuck, I would (and have) reassemble everything and take it to a shop to get it done. (cost me $100) If it is stuck, this means that the bolt is siezed inside of the bushing and is a MAJOR pain to remove. One way I have tried with success is like so: http://i578.photobucket.com/albums/s...lampHammer.jpg Pounding on the clamp as you tighten it. This took FOREVER on mine, but worked great. Also, be prepared to destroy the clamp. I bent 2 when I did mine. After I got mine done by the shop, I examined the shackle and found that it was bent from the inside. I believe they used an air hammer on the shackle itself to pull the bolt through. This effectively destroyed the factory shackles so I would not attempt this on my own. Once you have gotten the bolts moving, remove the nut and beat the bolt out of the shackle/leaf spring bushing being careful to not damage the threads. Once the bolt is flush with the bushing, you can use the punch to ram it the rest of the way out. You may need to raise or lower your axle via the jack in order to relieve the bind on the bolt and possibly your punch. I recommend doing one side at a time. Once you have all 4 bolts out, remove the factory shackles. Here is what you should be looking at: http://i578.photobucket.com/albums/s...r/IMG_5843.jpg Next, lower your axle to allow room for the longer shackles. Comparison: http://i578.photobucket.com/albums/s...r/IMG_5841.jpg Be careful not to put pressure on your brake line running to your rear axle when lowering it or you may tear the hose. http://i578.photobucket.com/albums/s.../BrakeLine.jpg Line up the new shackles using the jack to raise / lower the rear axle. Run the bolts through the shackles and leaf spring bushings making sure that they face the same way they did before. Tighten the 4 bolts. Lift the rear axle again until you can reinstall the 2 bolts that hold on the shock absorbers. Install and tighten. Raise the rear of the truck with the jack under your differential and remove the jack stands. Then lower your truck to the ground. Your truck should be higher in the rear. To correct this, you will need to lift the front via tightening your torsion bar adjusting bolts. In order to do this you will want to be on very level ground. Lift the front of your truck (I did mine one side at a time) and tighten the torsion bar adjuster by one revolution: http://i578.photobucket.com/albums/s...om/Torsion.jpg Repeat on the other side. Lower your truck and drive it in a "figure 8" then return to the same spot. Measure from the top lip of your rim to the center of your fender lip like so: http://i578.photobucket.com/albums/s...om/Measure.jpg The front measurement should be 1/2" lower than the rear to be level. If it is not, repeat the torsion bar turning until you reach the target ride height. The number of turns varies for each vehicle, there is no perfect number of turns. You are done, get an alignment and bigger tires =D Speaking of bigger tires... I am running 31x10.5's Which most everyone will tell you is impossible...Here's how you do it: Cut the front valence at the fender for clearance, Like so: http://i578.photobucket.com/albums/s...K/IMG_6014.jpg With the stock rims this is the only place it rubbed on mine at ride height (apart from at full lock) I have my torsion bars turned to where the front fender is .5" lower than the rear (level) when measuring from the bottom edge of the center of the fender to the top lip of the rim on flat ground as stated earlier in the thread. When stuffed (or when hitting a large bump) the outside edge of the front tires graze the inside lip of the fender. To compensate for this I beat that lip up and flush with the inside of the fender with a 2.5 lb hammer. It helps to take the tire off when doing this. USE JACK STANDS. (safety first) It should look like so: http://i578.photobucket.com/albums/s...r/IMG_6518.jpg That's it...the rear clears the fender entirely with no trimming. I think the front tires still MIGHT rub under a hard turn during EXTREME flex (I mean extreme...I have no bump stops lol) But it isn't enough for me to tell, or to hurt anything. I certainly do not rub under normal driving conditions. My tires DO rub under full lock (turned as hard as possible) on the frame rail and the sway bar when it is connected. Mostly on the sway bar. I just dont turn as hard as I can. Saves the power steering anyway. :icon_wink: You will only lose about 1" of steering wheel turn. Even if you didn't compensate, it only makes noise. If you get a 2" body lift,you should be able to clear without trimming. I personally hate body lifts though. Hope that helps =D |
Awesome write up. Should answere questions for many.:icon_attention::icon_clapclap::icon_sultan:
Is the adjustment a must do? If it is im guessing theres no way to do it at home right?
Originally Posted by Jisher
(Post 325664)
yea my bad i meant alignment. How much do they usually charge for something like that?
Nice guide, seems simple and easy to follow.
(Post 325914)
Nice write up by the way. better than mine... |
(Post 325960)
$60-$70.
(Post 325664)
The trick is to have the front wheels off the ground with the suspension under full normal compression. Another way to do it is to drive in a straight line... get out and adjust...drive in a straight line... get out and adjust... repeat as necessary. I simply use a tape measure to the center of the tires and set them for about 1/8" of tow in. I really recommend a professional shop do your alignment though. I go off-road quite a bit and I am always checking / adjusting my front end alignment... especially after bashing around on a tough trail. |
Firestone offers a lifetime alignment.
http://www.firestonecompleteautocare...FVZY2god7W6TAg I believe it's still a one-time fee of $140....pays for itself after the first 3 wheeling trips. :icon_playing: |
| All times are GMT -5. The time now is 04:16 AM. |
