Originally Posted by fishstick002
(Post 424896)
any one here
2'' shackles for 2nd gen are on ebay, $52 canadian. just got mine. they only took days to get here from L.A.
Here is 1 question.
In the photo story of the T-bar crank posted by a_tack, it says to jack up the front of the vehicle before adjusting the T-bar bolts. But in this thread, it is mentioned that the T-bar adjustment should be performed on a level surface, without jacking up the vehicle. What is more recommendable? |
The proper way to adjust the jack bolts is with the weight off the front end. To check your adjustments, you have to put the truck back on the ground and then drive forward (or backward) at least one truck length to settle the suspension. Then repeat until you get the desired height.
Originally Posted by swartlkk
(Post 445514)
:icon_shrug: Aaron |
The sway bar isn't going to make that much of a difference unless your front end is an inch or two higher on one side.
Good post, I wish I would have seen this before I did mine, I didn't use a sharpie I just watched my wratchet very closley.
now with shackles and a TBar crank should you get 2in bigger shocks if your doing 2 inches all around
front shocks I'd recommend. rear shocks you don't have to unless you want to. If I were you I wouldn't crank the tbars at all. will save you a lot of problems
