1997 Blazer radio install
anyone have any pics on what a aftermarket radio looks like installed. I was going to buy a new radio from crutchfield and it says the new radio will stick out 1 1/4 inches. I wanted to know if it looks tacky or if I should just keep my stock radio.
1 Attachment(s)
power acoustik PTID 8970 NRB
Thanks for the pic. That doesn't look bad. Did you have to cut out the back bolt for the stock radio to put the radio in??
uhhh i dont think so? this is my second deck in this blazer. but i dont remember doing any cutting of bolts to install my first one. wat deck are you looking to install?
I was looking at putting in a Dual XHD7714 in. Crutchfield says:
Installation Details Modified Fit - Requires Modification Installation Details for your 1997 Blazer » To install this product, you'll have to modify your vehicle. » Extension kit -- when installed, the radio will protrude from the dash by 1-1/2". » Unbolt or cut out the factory stereo's rear support bracket to make room for your new receiver. |
okay well I know for my new deck i had to cut out some plastic, which is the bracket that was mentioned above me. so yea i guess i did have to. haha sorry for the confusion
The Kenwood looks nice and flush. It sounds like the radio I want will be sticking out an 1 1/2".
My girlfriend had a Dual HU in her 2000 Ford Focus, it stuck out about an inch or so due to the way it was made. It has a drop down front panel and protrudes a bit. You push a button and the front panel comes out and drops down so you can insert a CD. It was ok but it developed a problem where it would just cycle up and down all day. It was very annoying. We replaced it with a Pioneer HU.
It also depends on the dash kit you are getting. Some of the EL Cheapo ones will make it poke out. I don't like the look of them at all. The ones made by Metra are good and the Schoche brand is decent as well. I already had a Kenwood in mine when I bought it. So when I replaced it with the newer Kenwood unit it was just plug and play. I'm not sure who made my dash kit but the texture and feel of the plastic matches the HVAC controls perfectly. I'm very happy with it. |
Maybe I'l buy a Kenwood instead. Thanks for everyone's pics!
| All times are GMT -5. The time now is 05:54 PM. |
