2ohm or 4ohm
http://cgi.ebay.com/ebaymotors/KICKE...QQcmdZViewItem
http://cgi.ebay.com/KICKER-CVX12-CAR...QQcmdZViewItem Which one is better, the 2ohm version or the 4ohm version? And what would be a good amp for these? |
RE: 2ohm or 4ohm
neither is technically better than the other. Each one provides different options for wiring. That is the major difference. Research which one can be wired to which impedences and after choosing which one will work for you, choise an amp that can match the impedence and RMS
RE: 2ohm or 4ohm
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
with 2x 2ohm dvc subs, you have to find an amp that puts out its power at .5ohm or 2ohms with 2x 4ohm dvc subs, you have to find an amp that puts out its power at 1ohm or 4ohms |
