6 by 9 speakers
hey jw would 6 by 9s be better for my soundsystem if i like clarity becasue they add bass but they still play music i could amp them up and stuff because otherwise i was just gunna add another sub but would 6 by 9s give me both clarity and bass
RE: 6 by 9 speakers
I can't help you with your speaker problems, but I may be able to help you get some people who can to respond. Use punctuation (the weird lookin marks on some of the keys on your key board).
RE: 6 by 9 speakers
they will sound a ton better(depending on which ones you get), and add a little bass. If you really want bass then get another sub.
RE: 6 by 9 speakers
If you want clarity get component speakers they will give you the best clarity with the tweeters just depends on the material its made of and you will have your midbass with the woofers but if your looking 4 6x9 for the rear you have to look if its a 2 way, 3 way or 4 way and how much its going to take to power them if you didnt already you can dynomat around your speakers or go nuts and cover everything it up to you how much you get into it and how much you want it to get to it could also reley on your headunit
RE: 6 by 9 speakers
ORIGINAL: 2000ZR2 If you want clarity get component speakers they will give you the best clarity with the tweeters just depends on the material its made of and you will have your midbass with the woofers but if your looking 4 6x9 for the rear you have to look if its a 2 way, 3 way or 4 way and how much its going to take to power them if you didnt already you can dynomat around your speakers or go nuts and cover everything it up to you how much you get into it and how much you want it to get to it could also reley on your headunit since this is a blazer, and blazer have 6x9 rears stock, im gonna hafta say just get some decent 6x9's and DONT amp them. for true SQ, there only needs to be a left and a right speaker (the front speakers), rear speakers throw the imaging off. so if you want some real SQ in your system, get some nice comps for the front (Focal, Rainbow, Seas, etc) throw 100-150w to each. then if you want, simply replace the rears with 6x9 unamped. |
| All times are GMT -5. The time now is 12:53 AM. |
