94 Factory radio
Is there a internal fuse on the factory radio ?
My new 94 blazer radio won't power on but the clock works. I like the factory look and would like to keep this radio. All connections in the back are secure and the fuse is intact. |
i believe there is a radio fuse in the fuse panel,if it blew your clock wouldnt work. sounds like the radios dead.
Wonderful
I need to find someone with a factory radio sitting around. I can't find what the problem is.
I have one out of an 01. Pay the shipping and I'll send it to you
I don't know if it will fit or not.
I couldn't tell you. You'd have to wait for someone else to comment. Mine is the standard 1.5 din head unit. No factory amp or anything special
Wiring harness between the years may have changed.
Go to metras website and see what harness adapters fit the two different years. If they use the same one then that radio out of the '01 should fit just fine. |
Did the check for you. They do use the same harness adapter so that '01 radio should fit plug 'n play style.
Alton, will there be any sort of radio security he'll have to deal with?
